Re: 1938/F 20 wierd cooling problem
Posted by oldiron29 on February 23, 2011 at 15:35:30 from (69.112.87.249):
In Reply to: 1938/F 20 wierd cooling problem posted by tugboattim on February 23, 2011 at 15:13:01:
Tug, The 3/8 hole in block should be a breather tube for block. You may have a blockage on lower elbow or in block. I would pull lower hose and make sure it is cleaned out. use a coat hanger to pull out debris. Also could put water in top elbow and flush it out. The rad will get hot. oldiron29
