Posted by CCAMBIS on February 23, 2011 at 19:36:29 from (71.128.203.159):
In Reply to: Carb bowl gasket posted by Zachary Hoyt on February 23, 2011 at 18:40:39:
the carb bowl should not leak fuel with no gasket at all while sitting idling. if it does the floats are set too high. if the carb can easily removed, turn it inverted and the floats and float arms should be parallel to the edge of the bowl and should appear the same from both sides. hope this helps..........
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
