Re: Carb bowl gasket
Posted by Zachary Hoyt on February 24, 2011 at 04:40:12 from (173.86.125.69):
In Reply to: Re: Carb bowl gasket posted by CCAMBIS on February 23, 2011 at 19:36:29:
Thank you. The carb doesn't leak while idling, only when the tractor is in motion.
Zach
