Re: 1066 hydraulics
Posted by Janicholson on February 24, 2011 at 07:20:45 from (199.17.6.194):
In Reply to: 1066 hydraulics posted by Michael Sheik on February 24, 2011 at 05:46:01:
Spool valves normally do not (cannot)leak past. If they are not centered, or in their hold position, they can bypass, or cause issues. Internal blown Orings in the piping and connections , or a pump sucking air/restricted intake, or worn, is a likely place to look. Jim
