Posted by Michael Sheik on February 24, 2011 at 05:46:01 from (199.153.192.249):
I had issues with what I believe is low pressures on the remotes last year and wanted to look into it before summer hits. Basically, lifting a 14' heavy disk it is slow to raise with 4 inch cylinder unless you rev it up to pto speed and it will raise it up and a little faster. Also, when using on round baler it seems to lift the gate ok but it is leaking off a little and not keeping the tension on bale. everything is good on the baler so I am thinking the remotes are leaking past. Is it just as simple as pulling the guts out of both the valves under the seat and re-oringing them. You think that will cure it? Any suggestions. I haven't checked the pressures on the MCV yet so not sure that couldn't be part of the slow lifting.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
