Posted by caterpillar guy on February 24, 2011 at 07:27:10 from (66.188.53.165):
In Reply to: 1066 hydraulics posted by Michael Sheik on February 24, 2011 at 05:46:01:
Take a pressure gage and plug it in to the lines on the SCV. Then with system warm and, at rated engine speed seewhat the pressure is with the lever pulled then check the other side and both valves. Should get around 2000 PSI or more. If that is low your pump is suspect or the relief valve. If pressure is good let valve back to neutral with pressure on gage se if it bleeds off if so the valves need to be re o-ringed. That is a simple operation easiest done off the tractor. With seat off the side plate removed 3 3/8ths bolts will remove the valves and the pins on the levers. Use a heavy rag around valve in vise to protect.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
