If it happens on all attached equipment I would suspect the tractor's valving (not the control valves, but check valves and pressure relief. If it is only one thing attached that lowers, I suspect the equipment's cylinder is bypassing internally. Lift the equipment and put a floor jack under it. Disconnect the couplers and let the equipment down. If it drops, it is at fault. Jim
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
