1486 Hyd outlets leaking off. Will not hold up equip.
Posted by Larry B 1486 on February 24, 2011 at 09:38:16 from (67.142.161.20):
I am having trouble with the hyd outlets not holding pressure. I can raise up the equipment but it drifts back down on both back outlets. I have 2200 psi on them, no problem raising anything just keeping it up when the hyd lever goes back to center. When cold it's a gradual drop but when hot it does not take very long for it to drop. Anyone have any ideals on what the problem is and what I need to do? The 3pt hitch stays up and does not drift down.
