Re: 1486 Hyd outlets leaking off. Will not hold up equip.
Posted by Owen Aaland on February 24, 2011 at 12:45:49 from (65.174.247.39):
In Reply to: 1486 Hyd outlets leaking off. Will not hold up equip. posted by Larry B 1486 on February 24, 2011 at 09:38:16:
Double acting check valves were not standard equipment on those tractors. The were available to keep from having the problems you are experiencing. As long as there are no external leaks the problem is either in the cylinder or the auxiliary control valves.
