Re: 1066 hydraulics
Posted by Owen Aaland on February 24, 2011 at 12:53:49 from (65.174.247.39):
In Reply to: 1066 hydraulics posted by Michael Sheik on February 24, 2011 at 05:46:01:
The MCV hydraulics are separate from the hitch. The failure to lift properly is most likely caused by a weak pump. As pressures go up the pump flow decreases.
The problem with the baler not maintaining pressure is either in the cylinder(s) on the baler or a auxiliary valve leaking past the spool lands. There is no repair for that valved problem other than replacement of the entire valve. Many balers have a double acting check valve mounted on the tensioner system to maintain the pressure rather than rely on the tractor control valve. If yours has a check valve that also may have failed.
