Re: Checking an alternator
Posted by Brownie 450 on February 25, 2011 at 03:59:58 from (66.43.241.198):
In Reply to: Checking an alternator posted by charlie M on February 24, 2011 at 16:29:52:
With this much time on the alt. the brushes are probably worn or hanging up in the brush holder. Especially in dusty conditions. If your voltage checks show the alt. isn't charging, I'd take it apart & look at the brushes. They are cheap.
