Posted by charlie M on February 24, 2011 at 16:29:52 from (74.34.200.218):
About 20 years ago I converted my M to an alternator and 12 volts and has worked great the whole time. Now I don't see any movement on the amp gauge. I'm either not charging or have a bad amp gauge. What's the test for the alternator - is it just measure the charging voltage at the battery? If so what would indicate the alternator is charging OK. I'm thinking most likely the amp gauge is bad.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
