Re: Checking an alternator
Posted by Janicholson on February 25, 2011 at 07:14:19 from (199.17.6.194):
In Reply to: Checking an alternator posted by charlie M on February 24, 2011 at 16:29:52:
Go with Old's process below. Max voltage should be 14.6 Maybe 14.8, If it was that high you would see needle movement. If the lights work, the amp gauge will respond to their draw if the tractor is off. This tells you that the gauge is working. Which alternator, and how it is connected is very important for determining what specific things beyond these, to suggest. The nail placed near the rear frame center bearing will show magnetic attraction if the field is getting electricity. It does not indicate that it is actually charging. Jim
