Posted by Owen Aaland on February 25, 2011 at 09:02:26 from (65.174.247.39):
In Reply to: 301 low oil pressure posted by mshultz on February 25, 2011 at 05:57:18:
Besides having a galley plug left out there are a couple of other reasons for low oil pressure on this series engine.
Check to make sure it has the correct gasket between the oil filter base and the block. There are three (?) different gaskets that will fit the blot pattern. You need to make sure the gasket used matches the filter base.
Another common problem with the original aluminum filter base is erosion of the pressure regulator valve. The original valve is of a fiber type material and they can get a hole worn in them and allow too much oil to bypass.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
