starting problems- stumped
Posted by JTKY on February 26, 2011 at 15:11:47 from (70.157.243.24):
I believe I have electrical problems - I have a 12 volt conversion with a 6 volt coil and a ballast resistor- replaced one wire today and then showed about 12 volts at the connection before the resistor and 7 after the resistor. Before that change, they were showing about 10 and 5. However still not starting. I took my battery in to load test it a couple of weeks ago and they said it was ok. When I charged it last night and today - the charger showed "rev polarity"- I have it connected properly. I have no idea what this means and if it has affected the electrical system and whether or not I can still use this battery. Any help would be appreciated. Thanks.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
