Spline Shaft Revisited (22-36)
Posted by Tom in Iowa City on February 27, 2011 at 06:01:22 from (173.30.220.194):
I have learned quite a bit.
Problem, again, is to try to get a tighter fit between the spline shaft of the transmission and the transmission joint (hub) due to excessive wear.
Here is what I have learned:
1. Probably no problem to run the tractor AS IS and except the wear. I will be running it quite little, although I want to take it to a show once in a while, run it a little around my shop from time to time.
2. To fix it:
a. Welding, milling and re hardening. Concerns with welding: A. getting a hard enough welding rod. B. softening of the shaft due to heat incurred with welding. C. need or no need to re harden the shaft.
A local shop estimated it would cost about 600 dollars to do this. A little rich for my blood.
A neighbor offered to TIG weld one spline at a time and then I use my sweat equity to grind to fit. Then we do a spline opposite to that one, again I regrind.
Question: would this weld be hard enough to be adequate? (It would be normal TIG weld, if there is a normal hardness with TIG weld.)
Question: would this soften the shaft enough that I would have to reharden it?
Could I take the welded, ground rod to a shop to have them re harden it? I understand re hardening might entail heating to say 1500 and then quenching and then heating to say 750 and quenching to draw it.
I have had a neighbor 30 miles away offer to help also.
What would you all do with this?
Thanks,
Tom
third party image
third party image
third party image
Today's Featured Article - A Lifetime of Farm Machinery - by Joe Michaels. I am a mechanical engineer by profession, specializing in powerplant work. I worked as a machinist and engine erector, with time spent overseas. I have always had a love for machinery, and an appreciation for farming and farm machinery. I was born and raised in Brooklyn, New York. Not a place one would associate with farms or farm machinery. I credit my parents for instilling a lot of good values, a respect for learning, a knowledge of various skills and a little knowledge of farming in me, amo ... [Read Article]
