Re: Spline Shaft Revisited (22-36)
Posted by Owen Aaland on February 27, 2011 at 16:31:12 from (65.174.247.39):
In Reply to: Spline Shaft Revisited (22-36) posted by Tom in Iowa City on February 27, 2011 at 06:01:22:
If you are worried about the clunk, assemble the parts with grease and then turn the hub so that it is driving the shaft in the correct rotation. Use some nails that will drive in tight along the splines and cut them off flush. The retaining washer will hold them in place. For light duty it will probably only last 15 to 30 years.
