Stuck hand crank and shutter contol
Posted by Yooper Farmall on March 02, 2011 at 13:05:21 from (141.210.112.16):
I"ve noticed the hand start engine crank and the shutter control level is stuck on the H I bought this summer. I wondered if this common and ask about any tricks before I dig into freeing them up. Any tricks to breaking loose the hand crank mechanism? is there a spring that you press against to make it engage under the radiator?
Did people purposely disable the shutter control when they removed distalate manifolds and starting tanks? I haven"t checked yet to see if the crank had a bead of weld holding it in place.
