Re: Stuck hand crank and shutter contol
Posted by glennster on March 02, 2011 at 13:35:25 from (75.57.126.3):
In Reply to: Stuck hand crank and shutter contol posted by Yooper Farmall on March 02, 2011 at 13:05:21:
the starting crank mechanism does get rusted and stuck pretty good. it is spring loaded. fine field dust works in there to help it stick too. use a pressure washer and blow out as much dirt and chaff as you can, then let it dry. liberal doses of you favorite penetrating oil, tapping and turning and eventually it will loosen up.
