Re: injector pump?????
Posted by Jimb2 on March 02, 2011 at 13:19:24 from (99.240.236.11):
In Reply to: injector pump????? posted by brett munsey on March 02, 2011 at 09:50:43:
Hi Brett, I suspect junk in the fuel tank blocking the outlets. The other thing that can cause this problem is a clogged fuel tank breather. Try loosening the fuel tank cap and listen for an inrush of air. A test is with a clean bucket to catch the fuel, remove the fuel line from the top of the first fuel filter and let it drain into the bucket. The fuel should come out the full of the fuel line. A temporary solution is blow compressed air into the fuel line from the tank BUT it will always clog again. The only permanent solution is to take the valves out of the bottom of both sides of the fuel tank, clean junk out of tank a blow compressed air thru lines to the first filter.
Good luck
JimB
Today's Featured Article - 12-Volt Conversions for 4-Cylinder Ford 2000 & 4000 Tractors - by Tommy Duvall. After two summers of having to park my old 1964 model 4000 gas 4 cyl. on a hill just in case the 6 volt system, for whatever reason, would not crank her, I decided to try the 12 volt conversion. After some research of convert or not, I decided to go ahead, the main reason being that this tractor was a working tractor, not a show tractor (yet). I did keep everything I replaced for the day I do want to restore her to showroom condition. ... [Read Article]
