injector pump?????
Posted by brett munsey on March 02, 2011 at 09:50:43 from (97.64.155.252):
I have a IH 574 diesel that has started losing power every now and then.It started last fall while using the loader the rpm's would slowly drop then come back up. I would give it more throttle but no change in rpm's then suddenly it would start to run fine again. I was hoping it was plugged filters but I changed them and it did it again the other day while I was moving snow. You can watch the tach slowly drop then come back up. It doesn't do this often but it has done it enough that I'm getting concerned. Could this be anything other than the injector pump hoping for a cheaper fix than that.
Today's Featured Article - 12-Volt Conversions for 4-Cylinder Ford 2000 & 4000 Tractors - by Tommy Duvall. After two summers of having to park my old 1964 model 4000 gas 4 cyl. on a hill just in case the 6 volt system, for whatever reason, would not crank her, I decided to try the 12 volt conversion. After some research of convert or not, I decided to go ahead, the main reason being that this tractor was a working tractor, not a show tractor (yet). I did keep everything I replaced for the day I do want to restore her to showroom condition. ... [Read Article]
