Farmall 450 TA issue
Posted by Tony_Idaho on March 02, 2011 at 18:22:23 from (184.99.120.118):
third party image
Hello,
I was hoping someone could give me some suggestions on where the problem is with my Torque Amplifier. When I pull back the lever, I do get into the lower gear ratio as expected. But after a while sometime 1 minute sometimes 15 minutes, it comes out of gear. Meaning the tractor is still running, but wheels are not turning. If I move the lever back to the front of the tractor, the tractor starts moving again in the higher gear ratio. Then if I pull back to lever it again goes right into the lower gear ration and I have to repeat this over and over.
Can someone explain in the picture I am attaching where the issue might possibly be.
I have some numbers to help me out on which gears you might be talking about.
