Posted by pete 23 on March 03, 2011 at 10:32:55 from (173.87.146.142):
In Reply to: injector pump????? posted by brett munsey on March 02, 2011 at 09:50:43:
Seeing air and foam in glass bowl means you have a restriction between bowl and tank and it is drawing air in around gasket of bowl. It some times happens that a baffle in fuel tank comes loose and lays over outlet. In that case I put a slot in fitting so it cannot shut off flow. This happens in the 450 diesels, don't know if your tank has baffles or not. Even a plugged fuel cap can cause this problem also unless tank has seperate vent which of course can become plugged also.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
