Re: Gear Grinding - part 2
Posted by Dellbertt on March 04, 2011 at 05:57:28 from (209.172.21.106):
In Reply to: Gear Grinding - part 2 posted by Enar on March 03, 2011 at 17:39:12:
I went through the same thing with a nice SA that I couldn't shift unless I shut it down. After I did the following it shifted smooth all the time.
Drain the old trans oil out - it's old it is prbably half water.
Flush it if needed.
Then fill with half 80-90wt and half Lucas HD Oil Stabilizer.
(You could use more or all Lucas if you wanted)
The Lucas is sticky and puts more drag on the gears to overcome the sticky pilot bushing allowing the gears to stop when the clutch is depressed.
Give it a try and I hope it works.
Dell
