Those engines have more timing marks on the than carter has little liver pill. Here is what you do. Take the cover off in front of pump, turn engine until the number 6 shows in the lower left hand corner of opening. This will assure you that you are on number one compression stroke. Then turn engine until 16 degrees btdc lines up on front crankshaft pulley. Take timing cover off side of pump and the timing line on pump cam should line up with the bottom of the pointer. Kind of hard to see that line but it is there. . Always back engine up several degrees and turn it up to 16 degrees again in normal direction of rotation after changing pump position. It is possible someone did not assemble timing gear correctly, but if you can get that mark to line up at pump at the specified degree it is good to go.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
