Re: Super A Shifter Problem
Posted by Janicholson on March 06, 2011 at 11:28:25 from (67.72.98.45):
In Reply to: Super A Shifter Problem posted by Brian2 on March 06, 2011 at 10:51:57:
The shifter could have issues if it was worn or loose at the pivot (just at the spot the lever enters the top cover) it is more likely the ball at the end of the part sticking down into the trans. That should be shaped to fit in the rail grooves with little play, and no interference. Welding it up, and grinding it to fit and work smoothly is the key. In the top of the trans are the shift rails. These must be aligned so the slots are equally placed and in the center (front to back). If there is one of them out of place it will be stuck. you might have to push on the tractor wheels to get the trans free to move the rails. Jim
