Shim them till they have a little compression. Make sure the hand throttle lever pulls the governor lever all the way to its max position when wide open. If it does not it will run slower than spec. The governor will limit max rpm. Search for From a prior post on this topic: The rod from the hand throttle has the governor control equalizer (U shaped metal) that slips on first, then one spring then the governor control pivot, then the other spring, then the last flange of the equalizer. The nut holds the equalizer in position, and is tightened to do so. The springs keep the sliding pivot centered. If the springs are week, putting washers on either side of them can center the pivot. The linkage should pull the governor rod to full limit of travel when in the rear notch of the hand lever, and all the way to the idle position when forward. Adjustment of this is usually not needed. if it is not going full travel when operated at the hand lever, washers could be used to move the pivot between the springs such that it does. In all cases the pivot should be between two springs. See diagram in caseih.com search for parts. Jim
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only
... [Read Article]
Latest Ad:
[More Ads]
