Re: Farmall 450 Tranmission cleaning
Posted by Tony_Idaho on March 07, 2011 at 19:40:27 from (184.99.96.113):
In Reply to: Farmall 450 Tranmission cleaning posted by Tony_Idaho on March 07, 2011 at 13:42:05:
OK, sounds like Diesel is the way to go. I'll probably drain what's in it, hopefully there is some type of fluid. Add in 3-4 gallons, run for a little while then drain. if it looks pretty bad. Redo again, and drain.
Once I drain it for the last time, Do I need to let it sit with the plug out for a while to let it air out?? If so how long is long enough?
Thanks Again.
Tony
