Re: Not Grinding Gears
Posted by ScottyHOMEy on March 07, 2011 at 20:57:22 from (70.105.235.106):
In Reply to: Not Grinding Gears posted by Enar on March 07, 2011 at 18:39:49:
Pretty work! What I'd suggest is to drive it enough to make sure the oil and the additive are mixked up good and open up the check level plug to draw it down to that level. One of the more common causes of leaks is overfilling, and it will leak out around the seals where the differential shafts pass out through the tranny case. Those seals are made to hold back what sticks to the shaft, not a puddle of oil.
That said, sounds like she's quieted down real good.
Enjoy, and happy motoring!
