Re: Re: Super WD
Posted by E F Bazaar on July 19, 2000 at 10:53:24 from (209.239.201.86):
In Reply to: Re: Super WD posted by David on July 19, 2000 at 10:46:22:
Thank you for the response so I know a little of what to expect.It has number one piston froze but is soaking.There was water I guess got in the piston cause the can on the exhaust stack rusted away or something. This looks like a big heavy tractor that could pull some weight around. I hear the heads crack easy and I appreciate the tip about shuting it down. I guess guys run them too soon and shut them down hot and too much heat. Is there a way to see it's cracked without taking it all apart?
Post A Followup
: Re: Re: Re: Super WD
