Re: 184 U JOINT
Posted by Boyce on March 12, 2011 at 11:02:23 from (68.143.146.81):
In Reply to: Re: 184 U JOINT posted by K-Mo on March 12, 2011 at 09:29:26:
well, lets see, if it is a ujoint it won't do it sitting still. What about the PTO belts? Are they turning when sitting still? The TO bearing should stop or change when I press in the clutch. Hopefully when I look at it this afternoon, I can narrow it down to one or the other...
