Posted by K-Mo on March 12, 2011 at 11:43:23 from (67.55.164.37):
In Reply to: Re: 184 U JOINT posted by Boyce on March 12, 2011 at 11:02:23:
The PTO belts are in use all the time. They run directly of the flywheel pulley. There are only four screws holding the drive cover on (cover between the dash and the seat). If you remove it you have access to inspect the u-joint. If the joint itself is good, it could just be loose set screws on the joint. If the joint would be excessively loose on the transmission end, the bore in the joint could be worn. That could require replacement joint, joint end or repaired with machine work. Yes, pressing the clutch pedal could stop or change the noise if it's a TO bearing problem. The TO bearing actually rides on the drive shaft and is often overlooked when it comes to lubrication. Regardless, if everything else looks good and the price is reasonable most everything can be fixed. Creeper drive and 3-point are considered premium options. If it does have 3-point, keep in mind that PTO driven 3-point equipment from the local farm store is not compatible with the 184. The PTO runs CCW at about 2000RPM instead of CW 540. Good Luck, K-Mo 3-184s & 4-154s
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
