Re: Farmall 656 motor issues
Posted by bobia on March 12, 2011 at 17:24:09 from (205.188.116.73):
In Reply to: Farmall 656 motor issues posted by andy stockmaster on March 12, 2011 at 17:18:06:
can you check if you have spark in wire going to dist. sounds like maybe a broken or loose wire that is where a volt meter is helpfull
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
