Farmall 656 motor issues
Posted by andy stockmaster on March 12, 2011 at 17:18:06 from (71.244.181.158):
third party image
third party image
tried gapping points took pics to see if i was doing it right. have concluded that there is no electric coming out of the dist. cap as tried pulling a plug wire off and checking for a spark with an old plug and got nother on multiple wires. any ideas on why i am not getting electric to dist? could the wires be one the coil backwards? thanks
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
