your point gap should be 18 thousands, I only see one wire in the distributor, the one from the condenser to the points, is the one from the neg side of the coil, if you have a generator, positive side if alternator, hooked up? if so, you might have a bad wire or resistor.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
