Re: Farmall 656 motor issues
Posted by farmallhal on March 12, 2011 at 18:24:35 from (76.4.174.122):
In Reply to: Farmall 656 motor issues posted by andy stockmaster on March 12, 2011 at 17:18:06:
Andy, The Super C I purchased had a break in the wire running from the switch to the coil under the battery box which is one possibility. If you have a voltmeter you can start checking the entire circuit from the battery through the switch to the distributor. I am mostly a letter series Farmall guy with tractors older then your 656 but the switch on your tractor I believe is more then the push - pull switch of the earlier tractors. You should check at the switch for voltage and then see if you have voltage coming out of the switch as the switch could be the bad component. From there if you have voltage from the switch check at the coil and make sure it is making it that far. If not you will need to check the wiring and whatever electrical devices are in the circuit for continuity as well. I wish I had some 656 experience to share but I'm just going on the tractors I'm familiar with which are pre-656 models. Someone who is more familiar with the later models will chime in on your thread as there are several of us on this forum wanting to help you through this, Hal.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
