The gapping looks great. A volt meter is needed (or test light) With the rotor and cap on, and points open as though you were setting the gap,and plug wires in and on the plugs, turn on the key and check for voltage at the coil small negative terminal (Key side) then check at the Positive side. There should be voltage at both terminals. Next close the points and try the same test. There should be voltage on the key side of the coil, and none on the distributor side. Jim
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
