Re: F460 Hydraulic Noise
Posted by Mark EC.IN on March 13, 2011 at 08:32:35 from (69.89.189.118):
In Reply to: F460 Hydraulic Noise posted by SteveF460 on March 13, 2011 at 05:39:04:
Check the "single and double remote" control settings.
They are the two values right below the dash (about boot top level. You can turn them with a adjustable wrench. If they are off just a little it will make the system howl.
I'm assuming a 460 is the same as a 560 with this answer.
..................Mark
