F460 Hydraulic Noise
Posted by SteveF460 on March 13, 2011 at 05:39:04 from (69.140.96.250):
My Farmall 460 hydraulic pump started making noises. The noise is intermittent (cycles/surges) and seems to increase/decrease in speed with the throttle. It goes away when I put the system under load by raising the fast hitch. I changed the fluid and filter, cleaned the orifice and replaced the o-ring on the piston in the relief valve. I also replaced the o rings in the 3/4 line going from the pump to the relief valve which was leaking. I checked the posts here already, but is there anything I missed?
