Re: Farmall Super H battery drain
Posted by Bob M on March 15, 2011 at 13:16:15 from (67.240.171.41):
In Reply to: Re: Farmall Super H battery drain posted by Janicholson on March 15, 2011 at 07:08:00:
Jim - Incorrect idiot light resistance would not cause battery drain. Reason is the idiot light circuit is open at the ignition switch when the switch is off and the alternator is not spinning.
Incorrect resistance CAN however affect alternator operation. Too high and the regulator won't "turn on" so the alternator won't charge. And too low the alternator will backfeed enough current thru the idiot light to fire the coil when the ign switch turned off. Thus the engine will not shut down.
Good question however!
Bob M
