Re: Farmall Super H battery drain
Posted by Janicholson on March 15, 2011 at 18:20:38 from (64.61.211.109):
In Reply to: Re: Farmall Super H battery drain posted by Bob M on March 15, 2011 at 13:16:15:
Thinking again. If the points were closed and tractor stopped, but the alternator continued to feed current to the circuit, the light would remain lit, and the battery would drain. There just might not be enough current to run the tractor ignition.
(personally I think it is an out of spec regulator in the alt) Jim
