An electronic ignition (eliminates and replaces points and condensor) is NOT any magic elixir or cure all for many ignition problems such as the distributor cap or rotor or bad plug wires or bad plugs or worn distributor bushings etc which may be even worse with an elec ignition if you run at higher voltages.........If the distributor has good bushings and you install a new set of points and condensor and have a good cap (no hairline cracks or carbon traces) and good plug wires n plugs plus a good coil you may be fine. However most people report improved starts and idle with an elec ignition BUT YOU STILL NEED A GOOD CAP AND ROTOR AND GOOD WIRES AND PLUGS.
If you are going to convert to elec ignition Id go with negative ground and if you swap to an alternator most also require Neg ground. . If you change grounds the ammeter leads need swapped and the coil is also polarity sensitive regardless if you use elec or points ignition.
If you do convert to elec ignition Id match up a high energy (12 volt if youre going to 12 volts DUH) coil with it to get the most bang for the buck the elec switch has to offer and use good quality plug wires.
A good H should start n run fine with an original 6 volt system at Pos ground if originality is any concern for you
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
