H ignition and 12 volt conversion
Posted by jaybradley on March 15, 2011 at 13:52:36 from (71.7.108.179):
Son is having trouble with his H farmall. We keep
tracing the problem back to ignition. Moisture in
the distributor to charging with a 12 volt charger
and frying the condensor and maybe the coil. If we
convert to an alternator charging system and an
electronic ignition set I keep thinking we can
eliminate most of our problems. Question is, is it
best to go to a 12 volt ignition set with a negative
ground or what is your experience? I see there is
negative ground and positive ground available.
