Re: H ignition and 12 volt conversion
Posted by Shawn in PA on March 15, 2011 at 14:19:13 from (24.154.38.87):
In Reply to: H ignition and 12 volt conversion posted by jaybradley on March 15, 2011 at 13:52:36:
Is there a ballast resistor installed before the coil? Or is it an internally ballasted coil? You said alternator conversion, most alternators are negative ground, so thats how it would have to be grounded. You can get postive ground alts, but they're expensive for what you're doing. Personally, I'd stay with points and determine how it's getting wet. Shawn
This post was edited by Shawn in PA at 14:19:36 03/15/11.
