Re: What went wrong on MD?
Posted by ihcarl66 on March 16, 2011 at 19:01:35 from (207.171.223.150):
In Reply to: What went wrong on MD? posted by BruceS. on March 16, 2011 at 15:37:21:
Simalar thing happened on my M at one time before I owned it, a ball bearing dropped out of the bull gear went through the bull and pinion gear broke into pieces and laid in the bottom of the rear end for who knows how long then one cool morning I started the M and the thick gear lube carried a piece of bearing into the gear on the input shaft it wedged between the teeth everytime the clutch was let out it would clunk clunk clunk an old farmer told me" on a farmall M everytime it makes a clunk in the rearend or trans it's money, stop and pull the top plate and see what the noise is" when the piece went in between the gears it took out the input bearing
