Re: Setting carb on M
Posted by John M on March 17, 2011 at 17:20:52 from (67.231.169.173):
In Reply to: Re: Setting carb on M posted by rustyfarmall on March 17, 2011 at 16:11:12:
Pretty much the same way I do it RF, except I look at the smoke coming out of the pipe at idle. Each tractor and its carb are different from the one next to it and each have their own quirks, so I start at 1 - 1 1/2 and adjust slowly until the smoke clears. Main is usually 3 turns out out my show tractors, but my working M gets 4.
