Posted by Janicholson on March 18, 2011 at 11:51:31 from (199.17.6.10):
In Reply to: MD tranny teardown posted by BruceS. on March 18, 2011 at 10:56:43:
Block up the fuel tank to avoid removing it! Take pictues of each step from different angles. Put bolts in holes in a piece of cardboard to be able to put them back in the same hole. Take the clutch plate (6) bolts loose not out, to remove the clutch shaft. Put a gag under the center bearing (where 4th -fifth gear is located to catch the rollers located there (SEE diagram on line) Use a skim of Blue RTV for a top gasket. Replace the top shaft seal while it is apart. Make sure the forks go back on the gears!! Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
