Re: 1940 Farmall A Tractor
Posted by Ron in Nebr on March 19, 2011 at 01:21:11 from (66.252.113.137):
In Reply to: Re: 1940 Farmall A Tractor posted by Jimmy Speed on March 18, 2011 at 19:47:48:
To the "A Experts"- was it common for these not to have a pto?
Nice little tractor, the cultivators being still on it makes it possibly a bit more desireable although some of the links have been welded on. The hood's mangled pretty good but probably repairable, and that's not the original steering wheel but that's not a huge factor either.
I'd agree with the 500-stuck, 800-motor loose estimate given above, depending as mentioned on wheel/tire condition. If the motor's loose(turns over) and the rims aren't rusted out and those rear tires are good, maybe a couple hundred more. If the rims/tires are junk but the motor's loose, probably 600ish. Stuck motor and junk wheels/tires I'd guess 300-400.
