Re: 1940 Farmall A Tractor
Posted by RN on March 19, 2011 at 10:20:49 from (205.213.104.125):
In Reply to: Re: 1940 Farmall A Tractor posted by Ron in Nebr on March 19, 2011 at 01:21:11:
PTO wasn"t a "standard" until maybe 1950. Belt power was more needed in many areas up until then. A was a special good cultivator, fairly good puller for engine size- but PTO equipment was not common at beginning and belt on right side would interfere with view for cultivator. Southern Tobacco famers liked the cultivating capability, the plowing and wagon pulling ability was also adequate for most of the small acerages allowed. Cub was also offset- but 1/2 the power of A so 1 bottom plow instead of 2 bottoms as A could use. As noted, excellent garden tractor. If you wanted to mow hay, a pull type tracion wheel mower or converted horse mower used.RN
