Re: Case-IH 3220 starter or solenoid
Posted by El Toro on March 19, 2011 at 15:23:49 from (108.3.200.96):
In Reply to: Case-IH 3220 starter or solenoid posted by Cathy on March 19, 2011 at 14:13:31:
Your starter may be jammed you can loosen the bolts and shake it to see that's the problem. You should check your battery cells with a hydrometer and see what your readings are. Should be around 1.260. What battery voltage do you get off your battery? You probably should remove the battery's ground cable and clean all battery connections until they're shiny. That includes the area where your battery is grounded on the frame, solenoid and starter. Hal
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
